AFR calculations
Fundamentos del ajuste de EFI
1844 Vistas
Should I assume you need a dyno to adjust AFR or could you just bring the engine to different RPMs to correct AFR?
The fuel table is not only about RPM but also about engine load. You can log your rpm, load, afr on the road and then adjust fuel respectively...
