AFR Tuning
Fundamentos del ajuste de EFI
2465 Vistas
I'm confused because when you started tuning the 350 you say you're targeting the wide open throttle are of the map. But you say also say it's at 1,000-2,500 RPM. surely on a badass car such as this that can't be wide open throttle?
G'day Aaron. Depending on how much load the car is under, you can absolutely get to wideopen throttle before reaching 2500rpm. Heading up a hill in 4th gear for example. That's why you need to fill in these areas of the map. You don't hit them often, but when you do, they need to be tuned.
oh, okay that makes sense then. thanks for the reply!
