air density
Fundamentos del ajuste de EFI
1457 Vistas
converting to the ranking scale, do we add 460, even if i prefer to use,
(absoulute atmospheric pressure- 14.7 PSI ??)
If you could clarify what you're referring to, please?
hey Gord, my question looks stupid after i went through the whole module,
We do need to convert atmospheric pressure to the rankine scale so the equation and result makes sense.
Understood!
thnx for your respose
