air density
Fundamentos del ajuste de EFI
1670 Vistas
I am not clear how you came up with 0.076lbs/ft3 14.7 /2.7 x 519 =0.01049 ?????
Am I not doing the equation correctly?
Apologies there is an error in that particular module. The result is correct at 0.076 but the formula isn't. If you multiply 2.7 x 14.7/519 you will get 0.076. We will be correcting this module in the near future.
