Another discrepancy
Fundamentos del ajuste de EFI
Módulo relevante: Cómo funciona la ECU > Cálculo del ancho de pulso del inyector
656 Vistas
01:05 We know that our injector duty cycle needs to be 46.2%, and we calculated the cycle time to be 20 milliseconds, so if we put these numbers into the equation, we get an answer of 9.24 milliseconds.
He says the injector duty cycle is 46.2% but uses the required fuel flow (0.462) as the injector's duty cycle in the equation.
