hi gents i know this is old ecu these days
i question towards this ecu has anyone have true understanding how to tune base fuel map on the fc edit software as my ecu software screen only has injection map which i have added my targeted AFR numbers but not understanding how to adjust my AFR mixtures to meet my target map!i know some models have a base map also with the INJECTION MAP page which fuel adjustments can be adjusted here! but my screen doesnt support it!
my understanding is it self adjust my mixtures through correct injector msec information added to my fc edit page and battery voltage lag times ! or am i missing something !
Hello i set the fuel table to my target afr then i tune via the afm curve as its actually measure the air flow into the engine and after i have done that i enable closed loop then do a final check of the curve
hi there
so you alter the AFM curve liner curve? but does this play a role in the whole inj map target table? so my understanding is if you olter the afm curve to suit/meet afr targets then basically your on the right track to correct tune?
i have my logged data etc from datalogging but once i have the info from the feed back from my engine afr etc how do i apply the mixtures to my map?
