Beginner tuner here, need help with throttle closures.
Fundamentos del ajuste de EFI
373 Vistas
Hello, I just finished going through the tuning courses here and I decided to try tuning my car, 2018 bmw 330i using bootmod 3. I got my fueling and my ignition pretty much how I want them except I am having issues with throttle closures. As I dial my boost closer to my target boost, my throttle seem to drop. The more my boost deviation is close to 0, the more the throttle dips. I’ve lifted all the limitations I can think of. I’ve tried adjustments WGDC tables, PID and Compressor map and I just can’t seem to get it right. I loaded my OTS map and I don’t see the same issue. The boost deviation in the OTS map is pretty much zero and throttle stays over 90%. Is there any table I need to address? Anybody have experience with bootmod3 with these cars?
