Both high and low imp.
Fundamentos del ajuste de EFI
Módulo relevante: Componentes EFI > Inyectores de alta y baja impedancia
1574 Vistas
I have an RX7 that has both high and low impedance injectors. I'm running a haltech elite do I still need a ballast resistor for the low imp. Injectors?
I think most of the Elite models can handle low impedance injectors. I just checked an Elite 1500 (which only does 4 injectors), and it states it has low impedance control with peak & hold injector drivers.
