Can lambda motec
Fundamentos del ajuste de EFI
475 Vistas
Hey gents just question will or has anyone ran motec can lambda 4.9 with link g4x ecu before if they work with each other or do the link can lambda are the same design or unit!
Hey Nunzio,
The MOTEC LTC can definitely work with the Link G4X, the Link help section has info on how to set it up 👍
thanks for help and input
