La venta termina hoyObt茅n un 30% de descuento en cualquier curso (excepto paquetes)
Cold IDLE Ecumaster (classic) m50B20 3wire valve type
Fundamentos del ajuste de EFI
Art铆culos t茅cnicos
Discusi贸n y preguntas relacionadas con el curso Fundamentos de ajuste de EFI
270 Vistas
Hallo 馃榿
im rexi i came from austria (upper austria) and im new here and i love the courses 馃憢馃徎
i have a little problem 馃珷
bmw 320 e36 M50b20 pnp adapter with emu classic
in the state cranking the engine start perfect but how can i hold the Idle on afterstart like 5sec befor state comes running i have try some works but no results maybe someone can help me
Here's the timer for after start idle control
  • Solo los miembros Gold pueden descargar archivos adjuntos. Obt茅n m谩s informaci贸n sobre c贸mo convertirte en miembro Gold aqu铆.
thanks for your support !
But i have try it from 5 to 10 sec nothing changed i think ecumster cant hold it right the idle valve
"I think ecumster cant hold it right the idle valve"
I have installed an EcuMasters ECU into a Volvo XC90 using a Volvo S60 turbo engine.
I am going to "go out on a limb" here and say that whatever is wrong with your idle control has nothing to do with the ECU. You must get the settings correct first.
What is the idle control mechanism for your vehicle?
Two wire valve?
Three wire valve?
Throttle body?
Maybe post your project file here.
驴Necesitar ayuda?
驴Necesitas ayuda para elegir un curso?
驴Tiene dificultades con el sitio web?
驴O necesita contactarnos por cualquier otro motivo?
