Distributor
Fundamentos del ajuste de EFI
Módulo relevante: Componentes EFI > Accionamientos de encendido
1029 Vistas
Is it possible to convert a distributor engine to a waste spark or coil over plug?
For most engines, yes, some will even have kits available for doing so, or can be adapted from later variants that do use electronics.
Probable the biggest hassle is adapting a toothed wheel and pick-up to the engine.
What is the engine you have in mind?
