Does Stoichiometric change with elevation or temperature
Fundamentos del ajuste de EFI
2710 Vistas
Was wondering if the Stoichiometric change due to elevation or temperature changes?
Does a Lambda sensor automatically adjust to the current conditions?
No, the stoichiometric air fuel ratio is a fixed value based on the composition of the fuel. This doesn't change with temperature or elevation.
