first time dyno tuning
Fundamentos del ajuste de EFI
2287 Vistas
few questions so when first tuning on the dyno. do i have to put in all the math to get the car running on the dyno or can i just use a basemap? just need a lot of tips and tricks that i can get use to tuning on the dyno thank you
You can tune from a base map, however you do need to go through the configuration of the ECU in a methodical manner to ensure that everything is properly set up. There is more to it that I can cover thoroughly in a single forum thread. I'd strongly recommend that you consider our Practical Dyno Tuning course. It covers everything you need to know for exactly the situation you're in now.
https://hpacademy.com/courses/practical-dyno-tuning/
