Flying magnet Msd cam position sensors
Fundamentos del ajuste de EFI
2089 Vistas
I have msd flying magnet plus a msd cam position sensor both hall effective sensor how do I configure this on the 2500 elite
When you go to system configuration it gives you a list of car sensor options but not this type of inputs
Hello Steven in the trigger set up area there is options showing generic tooth count and then the options to make it hall effect
