Fuel Correction Factor Table
Fundamentos del ajuste de EFI
806 Vistas
I have not started playing around with the vehicle yet.
But, taking a look at the software and instead of a VE table for fuel, this particular model is using "Fuel Correction Factor".
Would I be correct in assuming that the table will react just the same as VE when making adjustments?
