Fuel injection
Fundamentos del ajuste de EFI
2011 Vistas
Inquire about
After reading the car on Dyno appeared in the screen 11.8 now is a rich proportion
The injector system is 14.7! Ie 14 percent of the air + 7 of the fuel. The lower ratio is the rich ratio and the higher ratio is considered a small proportion!
Now the car is adjusted to the injection system divided by 11.8 / 14.7 = 0.802
Another question
What is the number to be divided into 14.7or12.5
What is the universally recognized fixed number?
thanks
sorry, it's a bit hard to understand your English.
Can you rephrase the question?
