Go to choices for MAP and Wideband Sensors
Fundamentos del ajuste de EFI
1845 Vistas
Just wondering what peoples go to choices are for wideband controllers and MAP sensors to converse with Link G4+ P&P ECUs.
Which are the best, and which aren't so good?
Thanks in advance
Steven
As far as MAP sensors go, just about any of the commonly available sensors will be just fine. I'd be more concerned with the range rather than the specific brand of sensor. That being said, Link do offer their own sensors that are nicely packaged so consider them as they are no more expensive than any other brand.
For the wide band controller I'd recommend the Link CAN Lambda as it's a CAN based controller and is plug & play compatible with the G4+.
Great Andre, thanks for the information. I'll check them out!
