Help setting the trigger signal on my FT450 D16 Dizzy oem
Fundamentos del ajuste de EFI
197 Vistas
Hi, I need help configuring the ignition timing signal on a Fueltech 450 for my 2000 Civic with a D16 engine and the stock distributor, using 24-tooth crankshaft and TDC signals.
I've attached photos of my settings. The car starts but doesn't run properly.
