In addition to passing DYNO, how to find MBT through road test?
Fundamentos del ajuste de EFI
2520 Vistas
If you can do repeatable acceleration runs and log a rate of speed or rpm change channel or calculate it numerically you can make small adjustments and compare runs.
Or you can drive to a dyno, and do it right!
