Injector firing angle
Fundamentos del ajuste de EFI
2823 Vistas
Just wondering if there is some information for injector firing angle ?
Did a search on the forum, but couldn't find. is it in the course as i don't remember it?
i'm sure it must be somewhere.
specific question: how to set the injector firing angle with a agressive cam ?
or would singel zone just be fine (330 btdc)
car info: 1.6, singel cam, compressor, max boost 20 psi. max rpm 7800. idle @ 1000 rpm.
answer found in a webinar : https://www.hpacademy.com/previous-webinars/injector-timing-on-the-motec-m1/
Hi Rens, there are about three webinars in the archive so keep looking and make sure you watch all of them.
