Injector offset
Fundamentos del ajuste de EFI
1297 Vistas
So on pressure differential in the injector, does the vacuum of the engine pull against the plunger in the injector making the injector hard to open or is that not really effecting the plunger and just pulling more fuel out of the injector?
