Intake Air Temperature limits
Fundamentos del ajuste de EFI
17665 Vistas
hi
my question here is how much is the high limits for the Intake Air Temperature
ive my own car reach 65 degrees IAT and i know it is high, but in this case do i have to pull some fuel or timing ?
Thanks
There isn't strictly a limit as such, however you'll find that as the temp increases the engine performance drops off since hot air is less dense. Often you'll need to richen the mixture and/or retard the timing to help prevent knock as IAT increases but it will depend on the specific engine and the fuel you're running. 65 deg C is very high though and will definitely be costing you power. I'll assume you're turbocharged and if so I'd be looking at a better IC option. A good intercooler should be able to get your IAT within about 15-20 deg of ambient.
