Intake Air Temperature Sensor
Fundamentos del ajuste de EFI
1919 Vistas
Hi: I watched that section and you suggested in front of throttle body. My question is I am building a jet boat with a blown and injected 400 sbc, the injection is a mechanical hat feed by a block fitted with 4 injector mounted to the back of the blower.I was wondering were to fit the air temp sensor in the hat.Greg
