Intake Air Temperature sensor
Fundamentos del ajuste de EFI
Módulo relevante: Componentes EFI > Sensor de temperatura del aire de admisión
982 Vistas
Hi there, so for engine with bigger turbos or superchargers the secondary iat sensor is fitted, the iat located at intake manifold position is for going at high load and a secondary iat near maf sensor or integrated to this is for restarting at hot or to have a good iddle?
