Knock decibel?
Fundamentos del ajuste de EFI
1689 Vistas
Hey is there a specific decibel or frequency for this knock? And could it detect engine bearing knock sounds?
Thanks
Hello, every type of knock sensor works in a hz (frequency) this data can normally be found in ecu help files like Link, Motec, Haltech, I always use it to listen for engine noises like bearings failing while tuning using Link knock,
