knock sensor adjustment
Fundamentos del ajuste de EFI
2028 Vistas
hi my frequency is 7.44khz in knock sensor parameters have 7.27 or 7.63 what's will be better?
Maybe the closer frequency will be the better way to use, but i could be wrong.
Let's wait for other opinion
I'd simply test with both and see if one produces a clearer signal to noise ratio. Chances are that either will be absolutely fine though.
