I have understood the theory concepts, Now i want to start tuning cars for practice. Ofcourse i will be starting with safe maps initially.
Can any one help me what tools i need to buy? Like im very confused there OG tools that are very expensive for a beginner and the clone tools are confusing.
How did you people start?
What kind of vehicle are you going to learn on?
Is it stock (unmodified)?
Does it have an aftermarket ECU?
I’m an SDE2 based in Bangalore and a massive petrolhead. I’m planning to pivot my YouTube channel toward a technical, "engineering-first" look at car tuning—specifically documenting the learning process from scratch.
I have a strong background in hexadecimal logic and system architecture, and I want to approach this as a developer. Instead of just "flashing" pre-made files, I want to learn to read the binary, identify map structures, and modify them myself.
My first project is my personal 2017 Honda City ZX (1.5L i-VTEC).
My Roadmap:
Thanks in advance for the help!
There are far more qualified people here to comment on your Honda specific needs.
I will say that if you are planning to do bench work to start with, or rather if I were in your shoes... I would get a bench top power supply first and foremost. I like my Hantek so far. It has been good to me for several years now.
Then, I would find the "scrap" ECM and a header/"pigtail" (probably remove that from the same car that I got the ECM).
Having set that up on a bench, I would then find a diagram for the ECM and begin pinning everything out to breakout pins/headers. This can be as simple as terminal blocks. Some people get fancy. Basically, you'll need something to attach an oscilloscope or a logic probe to do that you can measure your changes and this will be easier than a dangling bundle of wires.
I would also suggest building a simulator board for the crank position sensor, cam position sensor(s), temp sensors (air, coolant, oil, etc). Any sensor required by the engine to run would need to be simulated to "run" your virtual engine so that you can see the effects of your changes. Something to read the CAN data would also be a good idea.
As to how to change the flash, K-Tag is likely going to be the protocol you're going to need to read and write with (again, I defer to experience). I recommend buying an authorized, legit K-Tag master like Alienware. Clones are going to be hit and miss. The quality may wind up biting you, leaving you with a bricked ECM. Then there's the moral, legal and ethical questions surrounding cloned devices.
Anyway, once you have the bin file on the laptop or PC, you would use an editor like Winols or Ghidra. A regular hex editor should be able to get it done but... Ghidra is more like a project manager. I don't have a lot of experience in this part myself. Only brief exposure to Ghidra and then I decided to go standalone. The security routine on my ECM and the total lack of community interest left me climbing a very steep learning curve.
Which brings another point. It would be wise to do this starting out on a bench. Low to no pressure. Take your time and investigate. Buy the best intro level oscilloscope that you can buy 100mhz sampling bare minimum.
You can build esp32 scopes now that are decent. If you go that route, do your homework on power management and noise filtering. Buy good probes.
Good luck. This should at least get the gears turning in your head.
Thank you for the repsonse. It was very helpfull!
