Pressure volume cycle
Fundamentos del ajuste de EFI
1869 Vistas
Is higher compression better than lower compression in NA engines only or booster engines aswell?
Higher compression could be better for both N/A and turbo, BUT if you don't have knock resistant fuel it could actually be worse due to knock.
