Purchased video will not play
Fundamentos del ajuste de EFI
1018 Vistas
I get a "Sorry due to privacy settings video cannot play here" when attempting to view purchased course on a laptop. Does the same with chrome and edge.
Hey Arthur, I'm sure Marcin already sorted you out via email, but just for anyone else that sees this please disable Bitdefender on the HPA website. It causes this issue due to how Vimeo (the video player) tracks the embedded videos behind the 'paywall'.
You can Google this beforehand to confirm that it is safe to do so, there is discussion on how dumb this setting from Bitdefender is on some development forums.
You can also just use HPA in an incognito window with your plug-ins disabled if you prefer.
Hope that helps.
