Questions regarding software / hardware package is necessary to read, edit, write to Siemens SIMK-43 series ecu in early to mid 2000’s hyudndai?
Fundamentos del ajuste de EFI
192 Vistas
Hello, I’m taking the winols course and interested in reading, defining, editing, and writing with my stock 2005 Hyundai Elantra.
just have a few questions on where to get started, as I’m interested in learning and practicing the process and to get hands on.
Aside from winols, what hardware / software should I invest in to accomplish this? Will pcm flash suffice? KessV2? Also is this read/writable from the obd2 port? Or is this a bench flash ecu? Any advice and suggestions to point me in the right direction to stay will be greatly appreciated. Thank you.
