RelationBSFC with Lambda reading
Fundamentos del ajuste de EFI
1639 Vistas
Does value of Lambda ? If less than 1 (which means rich) means by default that BSFC value will be high ?
hello there is a lot of good info on this on the net sorry i dont know the specifics but a quick google will find the correct reply
Regards Ross
