Rod length.
Fundamentos del ajuste de EFI
1493 Vistas
What are the pros and cons of longer VS shorter connecting rod and is the difference worth worrying about? (Same stroke and deck height)
There is a webinar course on here you can view that deals specifically with the technical design decisions on Rod length, i watched it a few days back.
You have to scroll down until you find it or you can search using the below description
153 | Rod to Stroke Ratio Explained
