RomRaider and ECuFlash for a 2018 ADM WRX
Fundamentos del ajuste de EFI
Módulo relevante: Empezando > Introducción
704 Vistas
Hi Everyone
I am after a definition to use with RomRaider and EcuFlash for my 2018 ADM WRX. I could not find it anywhere so far, only for older WRX models.
Also, is there any other software or even on those ones mentioned, that we can do kinda simulation for the dyno before running it? (For learning purposes) Or any software that mimics it and I can play/test with it?
(Like for Cisco Switches, there's a software called packet tracer and there's also a game with a packet tracer built in, and you play and make adjustments with the real codes and stuff and see if they work...something on those lines).
Cheers,
Nate
