Sensor calibration - Bosch fuel pressure/temp
Fundamentos del ajuste de EFI
15 Vistas
The datasheet for the Bosch "Pressure Sensor Combined PST3" says that it measures pressure from 0.2 to 3 bar. In the "Characteristic 1" table (pressure), it says that sensitivity is 1,518 mV/bar. There is an offset listed as 96.43 mV.
Does this indicate that the sensor return begins at (96.43 mV, 0.2 bar) and then progresses to (1614 mV, 1.02 bar) and so on?
Thanks for your time,
Greg
Nevermind guys. I got it.
