spark advance between WOT shifts
Fundamentos del ajuste de EFI
2506 Vistas
during WOT, between shifts the spark advances 8°. after shifting into the next gear the ecu senses knock. what can be done to fix this issue? Set up is a ls3 turbo t56, hp tuners.
Can you post a datalog?
As Raymond has said, a log and perhaps a copy of your calibration will be helpful here.
