Standard conditions
Fundamentos del ajuste de EFI
1843 Vistas
That means that if the car is tuned in A cold Country if moved to warmer country it should be tunned again to take the most of the engine right?
Actually this is one of the benefits of modern EFI because the ECU can account for changes in temperature and pressure and alter the tune to suit.
