TFI Modules and cam syncs
Fundamentos del ajuste de EFI
1982 Vistas
In reference to making sure the ECU knows what position the engine is in, will a distributor with a TFI module provide that information to the ECU? For context the engine is a Ford 302 with a MSPNP2 ECU and a distributor. Is sequential injection possible?
Hello im not sure on the MS but certainly can on Haltech, Link, Motec etc so I would imagine the MS would be the same
Regards Ross
