Tuning Ignition
Fundamentos del ajuste de EFI
1897 Vistas
At the 19 minute mark, Andre says that at low RPM, ignition must be set earlier and at higher RPM, it does not need to be set so early. But prior to that, he says, using the graph, that as RPM increases, so does ignition advance. Arent these 2 statements contradictory? Can you please point out what im missing?
