What next?..
Fundamentos del ajuste de EFI
2615 Vistas
what course is recommended next after completing understanding AFR & EFI fundamentals courses, online Practice dyno tuning, road tuning or practical dyno tuning
The online practise dyno would be good for putting the theory into use, especially the 3 hour 1-2-1 support from Andre.
After that I would consider looking at whether or not you'll be tuning on a dyno and choose either the dyno or road tuning course to suit
Thanks for the reply of recommendation Chris much appreciated, i will weigh up my options & see what others recommend & go based on most popular advisory.
Road or Dyno Tuning would be my recommendation.
After I completed EFI Fundamentals I did the AFR course, Road Tuning, and Wiring Fundamentals (in that order).
I did Road tuning because I don't have access to a dyno so all of my tuning for the last few years has been road tuning.
If you decided to do Online Dyno I would recommend doing Dyno Tuning first so you have the basics of dyno tuning and it will help the more indepth material fall into place much easier.
Don't forget you can watch Andre's webinars to and they are all well worth the time to watch.
