shift light
2609 Vistas
this means thaht you could set the brake light in the dashboard and configure the shift for example , not to run but to change in the RPM where the response is improveable, like , 1º 3000, 2º 3500, º 4º 4000, 5º 4500 thanks for the answer.
OK, I take it that english isn't your first language :-), but I think what you're asking is either...
If some displays that have shift lights can be set so each light comes on at a different rpm? Yes, most can and also be set to different colours.
Or, if the shift light can be set to different RPM for different gears? Yes, some ECUs do offer that capability - with most engine, and gearbox rations, one will get best performance changing just before maximum rpm/the rev' limiter, but some close ratios like the highest gears may benefit from slightly earlier gear changes.
