Data input to MainLine ProHub
Ajuste del control de levas variable
3019 Vistas
Hi everyone. I wonder if any of you guys have MainLine's ProHub Dyno and could advice how to get CAN bus live data (like ign.timing etc..) in the Dyno. What interface do you use to link up the car to the PC ? I can't seems to find a solution would work with a generic OBD connector with OEM ECUs and MainLine themselves aren't really helpful regards this. Thank you very much.
This is actually a specific software option for the Mainline dyno that you would need to purchase from Mainline if you don't have it already. Once you have that software option you can then use a generic CAN adaptor (Mainline supply one that works well) that connects to a USB port on your PC. I'd suggest getting in touch with Craig or Todd at Mainline to discuss.
Thank you very much Andre, I did ask Todd. I was just wondering if anyone use a specific brand/model as generic CAN adaptor (instead of Mainline's Bluetooth one and works well for them. :)
