Degree wheel
Ajuste del control de levas variable
Módulo correspondiente: Habilidades prácticas > Cómo ajustar una rueda graduada
3312 Vistas
So once engine timing is set can just set the degree wheel to TDC does skimming an engine block or head would effect that ?
It depends on the engine design. In theory there will be a slight change with over head camshaft(s), as the driven side of the chain/belt will be slightly shortened, but in practice it's negligible and nothing to worry about.
With cam-in-block, like V8s and other engines using pushrods, there's no change.
