dynamic compresion
Ajuste del control de levas variable
1669 Vistas
to what degree does intake valve close effect CR?
hello it doesn't affect compression ratio much if any as the compression ratio is a calculation of bore stroke and head gasket thickness and combustion chamber, it does affect the cylinder pressure though, which is a totally different thing
Regards Ross
