Haltech - Cam Control Switched
Ajuste del control de levas variable
2472 Vistas
Just watching the ECU Configuration Module from the VCT Tuning Course, you mention setting up a Generic Correction due to Haltech's clunky dual map switching. How come you didn't enable the 3rd Axis (4D) on the Base Fuel & Ignition Maps against Cam Control Switch State? This is how i've been tuning with VTEC on Haltech/Honda combos and appears to work exactly as required.
As an example;
