bmw v8 m62 ecu stand alone
Ajuste práctico de la transmisión
1054 Vistas
Hello everyone
I would like to use a self-contained ECU on a BMW V8 M62B44 NO VANOS engine, cable throttle, indirect injection, but I don't have much experience with it.
What do you recommend? Have you had any experience with this engine?
How are the 4 knock sensors managed?
Thank you all
Andrea,
Most standalones will not have inputs with digital processing for 4 knock sensors, so depending on the ECU you'd likely use 1 or 2 of them.
I don't have experience with that BMW engine, but a quick search shows the cam tooth pattern isn't super common, so make sure the ECU you chose can support it. The crank seems to be standard 60-2.
Hello Andrea,
And to everyone else, this is simply my opinion from looking into this engine platform and the options of standalones available and what they offer.
I have been looking into this as well, however for a M60B44 hybrid. The only ECU that I have found that supports the 4 knock sensors and the cam tooth pattern with ease is the Motec M150 ECU .. pretty much every other stand alone ECU on the Market seems to be aimed at 4 and 6 cylinder options with two knock sensors.
Yes they are all capable of running the M62B44 Non vanos, but there seems to be some compromises with either injector drivers or CoP drivers and only 2 knock sensor options depending on which standalone ECU manufacturer you go with.
But if you were to say be building a performance engine from this family and didn't want to compromise or leave anything on the table, the Motec M150 completely fits the bill and has full capability with fuel, spark and knock.
Again, just my 0.02c
B'nZ
Thanks for the answers.
Do you think it is possible to manage this engine with only 2 knock sensors? I saw that maybe ECU link could do something..
hi! these are the pictures of the coils
it mounts two types of coils
thanks
Andrea
Lately when someone says BMW standalone I typically think MaxxEcu because they have a few developed CAN profiles for some of the popular BMW platforms. That might be valuable to your application. For 4 knock sensors, having 4 native knock inputs is rare but quite a few have 4 knock "channels" (including the MaxxEcu), it would just require an external knock->CAN or knock->0-5v unit to populate all the channels. In theory this would get it done but not sure how well it works in the real world. If it does work well it might be cheaper than Motec.
Thank you for your response! It seems strange to me that they do not develop for 4 sensors the other ECUs, but in that case, I could also work with 2 from what I understand, what do you think? Obviously with 2 lambda
