asymetrical suspension
Ajuste y optimización de la suspensión
Módulo relevante: Habilidades prácticas > Procedimientos de configuración inicial y altura de manejo
1066 Vistas
What to do with a car that has asymmetrical suspensions such as an oval car on asphalt?
As in?
The basic calculations are the same, except you'll need to do both sides, rather than just mirror one side.
Depending on the design, the rear may get confusing in a hurry, if using torque arms, uneven radius rod linkages, etc.
