Bushing preload
Ajuste y optimización de la suspensión
1971 Vistas
When dealing with poly, delin, or uhmw bushings would there be a need to preload the bushing? Since the center sleeve is not bonded to the bushing (atleast in most aftermarket bushings) there would be little or no binding at all or am i mistaken?
No need to preload these since they are not bound to the sleeve.
Okay perfect! Thats what i thought but wanted to confirm. Thank you!
