Foil Strain Guage (SG) Wiring. How is the SG Connected to an Analog Channel on a Data Logger?
Ajuste y optimización de la suspensión
976 Vistas
Hi,
This subject seems like something experimental but has anyone determined how to connect a foil strain guage to an analog channel on a data logger?
Thanks!
You will need a strain-gage amplifier to produce a 0-5 volt signal for most data loggers. Here are a few choices:
https://www.texense.com/en/products/controls-sensors-1-3/force-measurement-1-37/
https://www.raetech.com/Instrumentation/Programmable_Strain_Gauge_Amplifier.php
https://www.amazon.com/Hemobllo-Strain-Bending-Amplifier-Voltage/dp/B07KG6F7T3
If you don't have a spare analog voltage input, here is one that puts the results on the CAN bus:
https://www.izzeracing.com/products/strain-gauge-and-load-cell-amplifier.html
That is awesome. Thanks! Very helpful.
