static ride height
Ajuste y optimización de la suspensión
1921 Vistas
Hi. I own a Acura RSX. I have Ohlins coilovers and today I set the ride height as per the video in the course. 1/3 droop and 2/3 compression.
Now, even with roll center adjusters, my front LCAs are flat at best. Now if I raise the ride height, it will be more at 50/50 droop/compression, even more. The damper has a travel of 60mm.
What are my options so I can raise the car and keep the 1/3-2/3 ratio.
Thanks
