Track Width
Ajuste y optimización de la suspensión
2120 Vistas
The track width is mesured out side of the tires or in the midle? Thanks
The definition of track width is the distance between the middle of the tires. The easy way to measure this is from the outside of one tire to the inside of the other. This will be the same value assuming the tires are the same width.
